I have replaced the fixing film in this printer in a fuser that pressure roller, claws etc... look fine. About 6000 pages later, it tore. Will put an entire fuser in this machine but really don't feel that will solve the problem. Seems like it is "environment related" but no indications of it. Cooling fans etc are working OK. Any input will be a big help... Really scratching my head on this one... Are they overusing this machine ? Cannot find specs on this...
HP Laserjet 4200 Fixing film keeps tearing for what looks like NO REASON... ugh
Re: HP Laserjet 4200 Fixing film keeps tearing for what looks like NO REASON... ugh
I've got a group of machines that use fuser films like they're going out of style. One of them lasted exactly 6 prints. I can be fairly sure that the cause for my machines is entirely environmental. The machines are placed in a glass manufacturing plant. It's entirely normal to find a handful of broken glass in the paper path.
When I've been onsite for 3 or 4 hours, I'll get home to find glass particles in my pockets, ears, shoes, everywhere. It's like I've been rolling in broken glass. If there's a solution for this particular environment I don't know what it is. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
When I've been onsite for 3 or 4 hours, I'll get home to find glass particles in my pockets, ears, shoes, everywhere. It's like I've been rolling in broken glass. If there's a solution for this particular environment I don't know what it is. =^..^=Comment
Strange indeed.
Any unusual media? I know a high percentage of envelopes will significantly shorten the life of the fixing film (27% of it's normal life).
blackcat: Master Of The Obvious =^..^=Comment
You have significally helped me fix many machines and I am grateful..Comment
It's not widely known, but I generally respond well to techs that make a real effort, and I can see that you do. You're welcome. =^..^=If you'd like a serious answer to your request:
I don't know if this will help at all, but there were some aftermarket fusers where the fusing film would self destruct because it was too wide.
Sorry if that's a waste of time.Comment
The upper film does not roll with bushing on each end. It just slids over the heating element and there are end caps I'll call them but not really bushings. The fuser film has been a big problem with therse HP 4200 machines. Make sure you you a lot of grease when replacing film. No way to tell how long the film will last. There is a company called Metro Fuser that has modefied the HP 4200 fuser and uses a solid fuser teflon roller in there rebuild. I have never used one yet but I think if I was you I'd give them a try.Comment
Just as a side note Doug. My son worked for me rebuilding fusers in the shop and other parts of the copiers. 16 years old and could rebuild a copier for me. Got really good at it. Well he moved on and now lives in Springfield , Mo. He now fixes sowing machines. He goes to Tulsa , Ok . sometimes. Funny how things work out.
Anyway, The HP 4200 fusers were a real money maker for me. They riped the film all the time. I would really try one of the fusers with the solid teflon roller?
Good luck.Comment
Good luck.Comment
