HP CP2025 meter reading input
    replied
    Re: HP CP2025 meter reading input
    Sorry guys, that's all I've got. I've never had a chance to try it before.
    My Printer Job Language manual does not offer any new details on the @PJL SET command. =^..^=
  • hillbilly
    replied
    thanks blackcat on the text against set pages how should the info be typed I have 2 readings colour and monochrome to input
  • Wild Bill
    replied
    Hey Black Cat,
    I have a couple 2200 printers (w/out display) That lost the serial numbers .
    Would this be the same procedure? Thanks
  • HP:guy
    replied
    You can't. The only thing you can do is reset the maintenance counts.
    replied
    Perhaps these PJL commands will help you.
    First edit the .txt file for the correct serial number and copy count.
    The simplest way to send these PJL commands to the printer is to use the LPR Jar utility.
  • hillbilly
    started a topic HP CP2025 meter reading input
    I have had to replace the formatter on a HP CP2025. Network card on formatter failed. I have inputed the serial number but I cant input the meter readings to their correct number.
    any help would be appreciated
