HP color laser jet CM 2320 fxi mfp (HP needs more letters)feed roller advance routine
  • Wild Bill
    replied
    Re: HP color laser jet CM 2320 fxi mfp (HP needs more letters)feed roller advance rou
    a.Open the 2ndry Service menu by pressing the Left Arrow button and the Cancel button
    simultaneously.
    b. Use the arrow buttons to select Pick roller, and then press OK.
    Press OK again to confirm that you want the roller to rotate.
    c. Listen for the roller to rotate. When the roller is done rotating, unplug the power cord and then
    place the power switch in the off position.
    I confirmed it is the same procedure as cp2025 series
  • HP color laser jet CM 2320 fxi mfp (HP needs more letters)feed roller advance routine
    i have the similar models routine down pat. but just ran into this model, and it doesn't have the same LCD screen. even though,i still tried the old way. i need to rotate the tray 2 roller to replace it. if anyone can furnish me with the procedure id be grateful. thank you, Jim
