HP Z6100 large format printer
  • kiwitech
    • Oct 2012
    • 29
    a friend wants to buy a z6100 at auction and has asked me for advice ( i work on canon gear ). the printer is giving 93.11 errors. what is this error? and what needs to be replaced? i have about 40hrs to figure out if its worth buying. thank you to anyone who answers.
  • Kiran Otter
    • Dec 2013
    • 1115
    Re: HP Z6100 large format printer
    93:11 means the printer is unable to pressurize the ink delivery system (IDS). This could be something as simple as a poorly seated or bad ink cartridge, or it could be a broken part in the IDS itself, or a problem with the ink tubes that run from the cartridges up to the carriage.
    If remove all of the ink cartridges and can start the printer, and not get the error, then it's likely a bad ink cartridge. Otherwise I'd inspect the plumbing of the IDS and see if maybe just one of the myriad of hoses has come apart, etc.
    How much are they asking for it? I'm curious.
    • Kiran Otter
      • Dec 2013
      • 1115
      By the way, the error may not occur until you send it something to print; I don't believe it tries to pressurize the IDS on startup, only when you start to print.
      • kiwitech
        • Oct 2012
        • 29
        thanks guys . my friend decided not to buy it. not sure what they were asking
