I Have A HP P3015dn that will intermittently do a mirror image. Power Off the machine, and unplug it. Plug back in turn on and it works normal for a while but eventually starts to do it again. Thanks in advance.
Mirror Image
Re: Mirror Image
Wow! That's really strange. Does it affect only prints or also internal reports? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Re: Mirror Image
A LOOONNNG time ago, I worked on a machine that would occasionally do that. It had something to do with the laser mirror spinning the wrong way at start-up. The solution was to simply change the laser unit. This wasn't an HP, but that's exactly what it was doing.Comment
