HP Fuser Film Sleeve
  • ldfrepairs
    • Oct 2012
    • 148
    Can I use the same film used in the P4014 fuser unit in the LJ4250 Fuser unit?
    drugstore-onlinecatalog.com
  • subaro
    • Oct 2010
    • 1274
    Re: HP Fuser Film Sleeve
    Looking at your stats and see you posted 88 request for help, but have never replied to other's post for solutions. You have to give back sometimes.
    By the way, a few weeks ago you posted about a dell printing black only. i replied to you and suggested some info. you replied once and never posted what the solution was. did you solve the problem. This is how others will learn, when you post your solution. i wrote much lines and gave info to you that you should have the time to reply.
    so now you need hepl with hp or suggestions. Remember the forum is to help one another, and you have to contribute too.
    As to your question on the hp fuser. I don't think anyone out there have tried that really. But , get a measuing device, check the length and circumference and if they match exactly, then no reason it should not work. And worst case if it does not, just replace the fuser.
    • 1stcavvet
      • Apr 2015
      • 231
      I use the 4014, 4515,4250, films all interchangably, GOOD LUCK
      • Hansoon
        • Sep 2007
        • 3385
        Sorry to hijack this thread guys but can anyone please tell a KonicaMinolta guy what grease to use for the HP fuser films?
        Thanks!
        Hans
        • Blizzoo
          • Aug 2013
          • 608
          I use Uniflor and other grease (on small ppm printers) packed with compatible fuser sleeves.
          • Juddinga
            • Dec 2014
            • 16
            You have any way of knowing if the 4250 sleeves are lasting 200k pages in the 4015?
            • 1stcavvet
              • Apr 2015
              • 231
              Good sleeves and good rebuilds always last a long time don't forget new roller bearings, GOOD LUCK
              • ldfrepairs
                • Oct 2012
                • 148
                Thanks guys. I tried and it worked.
                • veka888
                  • Apr 2015
                  • 5
                  I do not think that it will go for 225k cicle becouse 4015 sleeve is better ( the film is fatter) but would like to test it. Maybe the 4015 film will give more cicles on 4250 :-)
                  • ldfrepairs
                    • Oct 2012
                    • 148
                    Wont give the copy count as per OEM but will work as a good fill in for a short period
                    • Wild Bill
                      • Jul 2005
                      • 774
                      Are you guys having short life with the rebuilt P4515 fusers? Just seems like they don't go too long and then they start jamming 13.05, 13.06 errors.
                      Izzy
                      • toner cartridge
                        • Sep 2014
                        • 33
                        its of course, its work .. also many fuser film is universal, too
                        _________________________________
                        copier, printer spare parts
                        • toner cartridge
                          • Sep 2014
                          • 33
                          correct.. its interchangably, many film sleeve film is interchangably , too..
                          spare parts for copier, printer
