Lexmark XM7263 service fan error
  • lumumbahasan
    • Feb 2020
    • 4
    [Error Code] Lexmark XM7263 service fan error
    I am working on a Lexmark XM7263 with a service fan error. The screen is blue with the service fan error I have turned the device off for 10 second and restarted and unplugged it and powered it back on still with the same error. I have changed out the control board and still getting the same error. I am looking for documentation on how to reset the device and I am not finding any. Thanks in advance for any assistance.
    • 23008
    Re: Lexmark XM7263 service fan error
    Have you given any thought to investigating a non-functional fan? =^..^=
    • lumumbahasan
      • Feb 2020
      • 4
      I have checked to into the fan not working there is no voltage coming off the control board. I have replaced the control board and fan and I still get this error 17:00 kworker /1:1:272. I have turned it off and waited for 10 seconds then I got error 17:00 kworker /0:1:287 then I tried to reset the machine by holding the 2 and 6 button it still goes right into the blue screen with error 17:00 kworker 1:1:272. I have unplugged the fan from the control board to check for voltage I got no voltage coming from the pins.
        • 23008
        It was on a different model Lexmark, but I ended up replacing the fan and the operation panel PWB. =^..^=
        • lumumbahasan
          • Feb 2020
          • 4
          A quick update with my Lexmark 7263, the service fan was not working due to the low voltage board. I was not getting any power to the main board so I replaced the low voltage and it is now working client is very happy. Thanks to all that helped.
