fujitsu scanner fi-6130 constant P in display
  • Jerrygbs
    • Dec 2008
    • 193
    [Misc] fujitsu scanner fi-6130 constant P in display
    Changed feed tires and drive tires, after reinstalling these parts the machine starts to cycle but stops on P. It should go 8 then P then 0 then 1. Also the lamps are staying on and won't turn off until adf opened. I'm a Canon copier tech just didn't see a place for scanners
    • 22808
    Re: fujitsu scanner fi-6130 constant P in display
    check sensors .. sounds like one isn't registering properly
    • Jerrygbs
      • Dec 2008
      • 193
      Thank you sir, after taking it apart found a pinched wire in the ccd harness
