Oce TDS400 Scan to File
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Scanning to the controller works. Also, I can "get" a file using and Ftp session from the controller. The problem is Scanning directly to a network folder using SMB. The controller is able to see the destination. The Net. Admin. Swears the username/password are valid. Folder permissions are set properly.
    Is there anything auxillary I can try in lieu of reloading the controller software/ performing ritual suicide?
    sigpic
  • ocehelp
    Oce TDS400 Scan to File Help
    If you are still having an issue with Scan to File via SMB, go to the following Oce technical support site - http://okb.oceusa.com and search "cannot scan to file SMB" for some possible solutions. If this does not work, you can call the software support center.
    Thank you.
