hi. everybody this is my first time using or registering on forums... i bought a Pitney Bowes C 180 was working ok.. but after making a service cleaning the copier didn't start i already cheked the fuses. themistor, lamps, continuity, fuser unit, developer, drum, etc. all are in good condition. i will like to know if there's some kind o reset using codes. i dont have any manuals nor list of error codes. i will thank any help... please... anybody... somebody...
does anybody Knows the "E 5 42" means on a Copier Pitney Bowes C 180 ?
Hi The Pitney Bowes C180 is also known as a Panasonic FP7718. Perhaps someone can interpret the code for that model. Check all paper path switch actuators, in case one has been dislodged. If I find anything further I shall reply. -
E5-42 on panasonic machines is total counter error code.Have you disconnetced the counter?Or more probably left the connector off whilst servicing the machine..Hope this helps..SiComment
supercuaz
supercuaz
i fixed the copier... thank you all
the problem was in the couter... the coil was open, i fixed soldering it, i connected back and works perfectly. now i have another problem... the paper tray (cassete) isn't working. have paper and isn't detecting. i alredy checked the sensors, moved some codes without knowing nothing just testing... i would like to know if i desactivate the paper tray after moving the codes or if i need to check it again. thanks
