Hi there, my Samsung SCX 4520 has suddenly decided that it doesn't want to copy a whole A4 page. It leaves the last 2 cm or so blank. I have tried using the flatbed and feed copy options but both come out exactly the same. I ran a flatbed test with the lid open and noticed that the imaging unit didn't travel the full length of the scan area, it stopped short of the full travel by the amount that is missing on the copies. There is a small white tippex spot on the rod that the imaging unit travels along to indicate - I guess - the place where it should get to before returning. So what would anyong suggest has happened here? Is it a new belt that is needed or is it something far sinister?
The machine is 2006 and has only just started to show toner low so very very little use in that time. When not in use it has been covered at all times with a plastic sheet and is in an area which never gets hot or cold beyond 50 - 70F.
Thank you in advance.
Axxe
Edit - Tried using USB for direct printing and that function works fine with no blank area. Pointing towards a mechanical malfunction in the scanner department?
Axxe
