Printer does not boot . there is power as the display shows a faint squares on display. when you switch off you see motor slightly move ?
Samsung ML 2551N Laser Duplex Printer
Just Manuals | The Internet's largest selection of manuals | Instant Downloads
Paul@justmanuals.comComment
I also belive it to be power board failure, check the contact points on the board with your meter for correct voltage etc!!!! just to be certain...
MasterchiefsigpicComment
We had one that used two power supplies within 6 months. The customer turned down the second one. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
