magicolor 2430dl
  • rbell12
    • Aug 2006
    • 83
    magicolor 2430dl
    customer brought this machine in with regristration problem. image shifts 1/2" down the page. we have no reference materials for these boxes. looks like the paper has no stop at the registration. this on both internal prints and prints from the computer. any help would be greatly appreciated. rb
  • kingarthur
    • 1222
    Re: magicolor 2430dl
    try reposting in the "konicaminolta" section, it might get noticed more by those who know
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • nmfaxman
        • 1705
        Replace the feed rollers in the tray.
        Worn sep causes the paper to feed an extra sheet that throws off the timing.
        • Hansoon
          • Sep 2007
          • 3312
          Try first replacing the black pad on the synchro roller solenoid and relube the clutch. All machines of these series have EXACTLY the same error. Machine in the picture is a MC-2490MF but construction (not location) of the solenoid for the MC-2430 is similar.
          Location of the synchro clutch and solenoid however is hard to reach and will take for the first time one hour labor.
          Hans
          " Sent from my Intel 80286 using MS-DOS 2.0 "
          • rbell12
            • Aug 2006
            • 83
            Thank you Hans. Replaced that solenoid with one from a 2590. Works like a champ. The input from everyone was much appreciated.
            • Hansoon
              • Sep 2007
              • 3312
              Glad if I could help. Hopefully you took the opportunity to re-lube the clutch itself as well.
              Hans
              • apachelry
                I have a 2490MF and probably the same problem : paper is not fully printed (offset of 4 centimeters above the sheet).the sheet is not completely ejected from the printer
                the error message "paper jam" appears.
                do you think it's the same problem ?
                • apachelry
                  Incredible! It works!
                  My little black pad was not at all sticky ... I put tape around and that's it!
                  I don't not understand what has changed but it works ... thank you!
                  • Hansoon
                    • Sep 2007
                    • 3312
                    Great! Thanks for the feed back.
                    Hans
