MP C4502 Hardrive size
  • Cipher
    replied
    Re: MP C4502 Hardrive size
    Originally the 4502 came with an 250Gb 2.5" SATA HDD but the official replacement part is now an 320Gb HDD.
    As long as the controller can detect the HDD, it should work.
  • ikerl
    Guest replied
    replied
    Originally posted by ABS tect
    What is the Hardrive size for an MP C4502?
    Look on the label on the existing HDD
    And also how do you get into the sc mode on it?
    Create an error on the machine. Or did you mean SP mode. If you meant SP mode, you should not be working on Ricoh equipment as it is common knowledge for all Ricoh qualified technicians.
  • ABS tect
    started a topic MP C4502 Hardrive size
    What is the Hardrive size for an MP C4502? And also how do you get into the sc mode on it?
