View Full Version : Bizhub 600 locked up
peter@digitalswebsite.com
06-12-2015, 09:59 PM
Powers on, but only the hour glass shows up, never comes ready, try the trouble reset without any luck
fixthecopier
06-12-2015, 10:07 PM
If you search this forum you will find post about that issue. Sounds like you may need a board.
Probably a faulty flash card
Brett GS
06-13-2015, 07:07 AM
Had this before snd was a faulty flash card
allan
06-13-2015, 07:49 AM
Yea also had the CF card cause the problem.
fixthecopier
06-13-2015, 11:02 AM
You guys were lucky. Last time I saw that screen, it cost me a PCB.
06-15-2015, 02:10 PM
Would any of you have a CF card flashed and ready to go I could purchase?
darry1322
06-15-2015, 02:34 PM
Same here.
Downunder
06-29-2015, 10:25 AM
Go to another BZ600 that you know is working and copy the card contents - then go back to faulty machine and "cut" the contents of the faulty card and copy the good files onto the flash card. DO NOT FORMAT FLASH CARD.
You will need to change serial number, and set up copier again, Hard drive, fax etc.
There are two cards. System and control.
Good Luck.
07-06-2015, 02:20 PM
Do any of you have the cf card firmware you could upload to drop box I only have this one machine, so I dont have the option to get the firmware of another machine
