View Full Version : Error Code C1105 on a C654e with FS535
big jase
06-15-2015, 05:51 PM
Has any one had this fault? can't clear error i have swap motor (m6) no joy
splblazer91
06-16-2015, 04:23 AM
is this happening while using 3 hole punch paper?
big jase
06-16-2015, 07:54 AM
No every copy/print
big jase
06-30-2015, 09:51 PM
Solved the Pin had split in the drive gear see attached pic gear 15 pin k
splblazer91
06-30-2015, 11:14 PM
The actual pin broke or the slot in the gear where the pin goes?
big jase
07-01-2015, 07:13 AM
The actual pin. It the hollow type. Replaced with a solid one
Brett GS
04-12-2017, 06:40 PM
Thank you,going to assist one of my techs tomorow so this will be the first thing i check.
Woxner
04-12-2017, 09:32 PM
also check the ejector unit. i had this two days ago. the claws come off and jam it uo
