Konica fs-603 jamming
  • acsolutions
    • Jun 2010
    • 519
    [Jamming] Konica fs-603 jamming
    Hole punch home position, off! Path is being constructed buy center pin! Is there a way to adjust the position or eliminate the whole punch entirely! Thanks
  • copierwhisper
    • Mar 2013
    • 78
    Re: Konica fs-603 jamming
    I've had the center pin stuck down before, I removed the punch unit to clean and lube. Found a mylar bent and causing the issue, trimmed the mylar and reinstalled the punch unit and it worked great.
    • Cookr
      • Dec 2011
      • 184
      You can turn hole punch off in the service mode under finisher also.
