View Full Version : yellow background print bizhub c364
toony
06-20-2015, 07:32 AM
I use a bizhub c364.
Yesterday it started printing all yellow background for any colored print i have. gues it might be some sort of yellow toner spill. but it does not do this when i do a print in greyscale. pls what can be done!
fixthecopier
06-20-2015, 09:45 AM
Most likely, replace the yellow image unit.
allan
06-20-2015, 10:37 AM
Have you tried to use the corona cleaner?
KingofMorton
06-20-2015, 08:32 PM
Cut a long strip of paper and slide it under the yellow drum and block the laser glass. If the yellow goes away then the laser is the problem.
shamnad abdullah
06-24-2015, 09:34 PM
Remove the high voltage board and assemble it,make sure that all connections are touching properly
best of luck
dhaneshkumar
09-01-2018, 04:29 PM
I have same issue konica c452 printer plese help me.
Synthohol
09-01-2018, 07:01 PM
upgrade to a newer machine.
or maybe tell us what you have done so far? like any of the advice above?
