big jase
06-30-2015, 09:42 PM
has anyone seen this issue
tray 1 is set to custom paper size, i can alter for individual job to say A4 paper feeds fine, but once the machine resets back to default it goes back to the custom size with set values, no matter what the size guides are set to in the tray
I have swapped over the VR pots from tray2 and fault stays in tray 1 so the Pots are fine also tested in i/o mode i get the same values from either tray MAX/MIn etc.
Also i have tried to run tray adjust in service mode, still same issue.
Is this down to a machine setting?
