J_B
07-01-2015, 02:54 PM
I have a new 2551ci with job accounting enabled. All pc's work with the exception of 1 Windows 10 laptop.
Issue: When printing from 10, the machine errors with improper code. But, if you go into the printer properties and select "test page" it WILL print that page fine.
The code is good and works on all other pc's. All codes have no restrictions, solely being used for bill back.
This machine is in a realtors office so I have the job accounting setup to "pop up" due to multiple users per workstation. I also tried to just embed one code to see if that helped. SAME ISSUE!??
I installed the print driver manually as well as through the installer. I've also "shared" the driver on another pc (peer 2 peer) and then installed as a "network" driver on the 10 box. SAME ISSUE!?? Even if I have the "shared" pc due the page rendering....SAME ISSUE!??
I've also reflashed the firmware to the newest 3.02 firmware.
Anyone else seen this issue? Any help would be greatly appreciated!!
JB
JB
