View Full Version : Miscellaneous Severe paper curl from built-in finisher
Bob Wescott
07-06-2015, 04:20 PM
Have a bizhub 363 that is reasonably happy, but paper curls excessively exiting from FS-529 finisher, sometimes pushes previous sheet(s) out of order or on the floor. Is there a way to decurl in this finisher? Tried everything with paper.
allan
07-06-2015, 04:41 PM
Check your paper quality and fuser temperature.
Are u using generic toner?
Bob Wescott
07-06-2015, 05:00 PM
We tried very good paper that works like a charm elsewhere. Strictly OEM toner. I thought there was a de-curl adjustment someplace. We'll check the fuser. Thanks!
emujo
07-06-2015, 06:40 PM
Remove the finisher and run copies...No curl---problem with FS, Curl---problem in fuser...Divide and conquer, let us know what you find. Emujo
allan
07-06-2015, 07:10 PM
The B363 does not have curl adjustment. I had to drop the fuser temp on this model before to get the finishers to stack correctly. I think the machine does have a setting that would allow you to change between quality and production mode.
Bob Wescott
07-06-2015, 09:05 PM
Will do. I'll let the forum know what transpires. thanks.
