View Full Version : Bizhub c652 TCR level Black to High C-2558
freixi
07-09-2015, 12:21 PM
Morning all
Bizhub C652 errorcode C2558
y have the TCR level in Black unit to High (11,50) normal is ~7-8
its possible this to reduze the TCR level?
Y have the level in service mode +3 and the max level to +10 and not result..
many thx for help
Freixi
i would say your dev is over life or there is a blockage from toner hopper to your developer unit. Manually add toner and if the value changes then its probably the dev.
freixi
07-09-2015, 01:24 PM
Thx Max,
Ok, add toner to developer Unit?
if that is too high is missing toner ?
I thought if that is too high that he has too much toner. ;)
Y testing and report.
Thx Max
freixi
07-09-2015, 03:12 PM
Hi Max,
many thx, add toner to veveloper and the bizhub its runing normal.
The Level ist ok..
thx for reply
Freixi
allan
07-09-2015, 06:02 PM
You can try to de-tone it, then reset it but the real problem is there is not enough developer left.
freixi
07-09-2015, 06:41 PM
Yes, the developer unit did not have enough starter.
Y change the developer unit and the bizhub running normal, TCR ~7.4
freixi
copier tech
07-09-2015, 07:30 PM
Just to add you can save all the old image units inc black dev unit then if any unit has a print quality issue due to low dev you can easily top up the toner/dev mix from the old units works great (assuming the drum isnt worn)
freixi
07-09-2015, 08:14 PM
:) nice tip :)
thx...
y have 3 or 4 Developer units ;)
many thx
Freixi
