View Full Version : BH C452 black toner TN413K vs TN613K
Desert Rat
07-10-2015, 09:22 PM
The 413K is for the C452 and the 613K is for the C552/662.
I got the tn613k by accident. My question is, if I cheat the key on the 613K it will fit
in the C452, but is the toner the same as in the tn413K?
DR
EarthKmTech
07-10-2015, 10:19 PM
I believe the machine will still reject it as chip will still tell it that it is the incorrect version.
as for the toner itself it isn't any different, its sold as 2 versions for "marketing" reasons.
jrf
07-11-2015, 06:41 AM
Yes it works
Desert Rat
07-11-2015, 02:38 PM
Thank you for the fast reply Earthkmtech & jrf.
Good point about the chip. I'm not going to make habit of doing
this, but I didn't want to waste it if i don't have to.
Jrf, you say it works, just like it is? No changing the chip,
just remove the key?
Thanks again
DR
konica7022
07-11-2015, 07:32 PM
DR
WOW exactly the same question i was thinking to post yesterday, coz i asked the dealer for c452 black toner and the guy gave me tn613k, i did a lot of research on toner and though of having it changed to tn413k, but i was in the middle of copying and machine asked for new toner as k is depleted, so i went ahead and installed new TN613K and it started working fine
what i understand form googling is this
Konica is manufacturing Smitri polymerized Toners since 2000 now they have smitri HD & smitri HD+ toners
all machines starting from c451 series and c452 series use the same toner (please correct me if i am wrong) the packing and model no. is different but same from inside
Thanks again
DR
there is no need to change the chip it same will work fine in C452
konica7022
07-11-2015, 08:15 PM
Not related to the topic but my c452 USB is not working
when i plug it it in it detectes the USB but the screen to print or scan wont POP UP?
EarthKmTech
07-12-2015, 09:28 AM
That's interesting. I have had the wrong black version be rejected before. Does the 413 work in the 613 machine? wtf is the point of having both versions then ?
allan
07-12-2015, 09:46 AM
Better to create a new thread.
Does the small USB icon on the bottom of the screen display? Have you tried a different port?
konica7022
07-12-2015, 05:11 PM
yes the icon show in the bottom, but the menu asking for print or scan does not pop up! and there is only one USB port on c452
AND EarthKmTech (http://www.copytechnet.com/forums/members/earthkmtech.html) what in the world happened to your avatar?
i dont know if any one tried it or not but 413 should work fine too in c552 in theory
allan
07-12-2015, 05:22 PM
Look under. Administrator -> system settings -> user box settings -> external memory function. Make sure print and scan is switched on.
Desert Rat
07-13-2015, 02:01 PM
Earthkmtech, the reason for two versions is money. It's different so they can charge a different price.Usually more.
Konica 7022, thanks for your reply. I assume, your C452 is still running ok?
At least I won't get stuck with it.
As far as the usb thing, keep it going. I would like to know how it turns out should it happen to me.
And thank you everyone, team work makes a difference
DR
konica7022
07-31-2015, 07:14 AM
Allan
"Look under. Administrator -> system settings -> user box settings -> external memory function. Make sure print and scan is switched on."
Thank you, its working now
DR
Yes i my 452 is still working fine with tn613k in it .. so i guess it safe to say that they are the same :)
Desert Rat
07-31-2015, 01:26 PM
Thank you for the update and thanks for the pointer on the use of the usb drive.
2 problems 1 thread
good job
DR
