View Full Version : DI 650 - Charging grid MANUAL adjusment
Dougall
05-25-2008, 12:30 PM
Good Morning Guys
Instrucctions say the grid should be adjusted MANUALY according to the value on the flange of the drum + - 5Volt.
And that the range of input is 0 to 255
The value we read in the flange of our drum is 744.
Aparently we are not understanding the instrucctions on the service manual because we cant do this adjusment MANUALY
Thank you for your help
mtech
05-28-2008, 02:55 AM
Why do you need to manually adjust this? It is the first step? I never adjust this. Just do the other steps and all will be fine.
nmfaxman
05-28-2008, 03:36 AM
This is what we call a DFW.
Stands for "Don't Fool With"
Run the auto adjustments.
rocky246
05-28-2008, 03:45 AM
This adjustmemt is in 36 mode. Go to 36 mode and select Process Adjustment. Select High Voltage Adjustment. Then select HV adj. (charging grid voltage). Under the brown drum cover is a grid pin that looks like a silver coin. Press start in this adjustment and measure voltage at this grid pin. Adjust using keypad to set the right voltage. This should be done everytime you replace the drum. Unless the voltage on the new drum is somewhat close to the old drum.
cobiray
05-28-2008, 04:14 AM
That's the nice way to say it.:D
mitchl
05-28-2008, 07:55 PM
This adjustment is in 36 mode. Go to 36 mode and select Process Adjustment. Select High Voltage Adjustment. Then select HV adj. (charging grid voltage). Under the brown drum cover is a grid pin that looks like a silver coin. Press start in this adjustment and measure voltage at this grid pin. Adjust using keypad to set the right voltage. This should be done every time you replace the drum. Unless the voltage on the new drum is somewhat close to the old drum.
The grid needs to be set according to the tag on the new drums flange when ever you replace a drum. You may also want to do a thread search for the drum ground mod and the bias mod as these are the key to keeping the toner puking monsters under control, since we re-did all ours at PM and put on the mods they are kicking some serious butt!
