View Full Version : Replace imaging unit K
Jhonjon
07-14-2015, 07:52 PM
Good day,
Gentlemen, I need your help regarding Konica Minolta Bizhub C35. The machine indicate replace imaging unit K, but when i replace the unit the same message appear. I try to clean the chip on the machine which contact to the drum unit but still the same. Machine is working scan, copy, print and fax, only the message bother the costumer. Any suggestion is highly appreciated...Thanks...
allan
07-14-2015, 07:55 PM
Are u using after market chips?
It happens from time to time with those chips.
Jhonjon
07-14-2015, 07:59 PM
We are using all original consumables and parts...
allan
07-14-2015, 08:18 PM
Then there is a bulletin out for that. Its a crap machine. TAAU1100165EN00
There is only one way out of that, actually three.
Replace MFPB
Repair MFPB
Replace machine
Its a crap machine.
Its not not as good as that....
Jhonjon
07-15-2015, 04:42 AM
Replace MFPB
Repair MFPB
Replace machine
Thanks for your feed back guys. I will try it, and inform you for the result...
EarthKmTech
07-15-2015, 09:06 AM
interesting that it would suggest replacing the mfp board when as always the tc and iu csic harnesses plug into the printer control board.
Make sure none of the contacts for either the toners or the IUss are damaged and shorting to the sheild - it will disable communication for both the toners and IUs even if just one is shorted.
