View Full Version : TA620 adding toner none stop.
jmaister
07-22-2015, 03:13 AM
The machine also says check toner cartridge. (not my actual call so i dont know the detail)
We are thinking along the line of toner sensor, toner supply motor, or DV? KDA has a 6030 case where the toner supply drive was replaced.
Has anyone else encountered one? what was the solution if you could kindly share?
thx.
tmaged
07-22-2015, 05:47 PM
Set U152 to off.
blackcat4866
07-22-2015, 11:53 PM
I had a brand new CS-8030 that would not add toner right out of the box. There was a deformation of the "D" shaped bore in the toner cartridge drive coupler. With the right side cover off, I could easily observe what was happening. The coupler would not spring back because it was too tight on the "D" shaft. Ten minutes with my jewelers files fixed that. I opened up the bore just enough to let it slide on the shaft. =^..^=
Kyo fan
07-24-2015, 07:10 PM
I would try replacing developer unit 1st.
JUAN C DLS
07-26-2015, 01:04 AM
Check toner sensor with simulation.if sensor is reading ok, then
Vacuum and clean the DV unit, then run DV set up again.
Copyguy71
07-28-2015, 10:52 PM
The toner drive gear on this model has a one way bearing that will strip, causing the machine to constantly run searching for toner. I've had to replace the toner drive pack many times
jmaister
08-13-2015, 02:15 AM
ding ding, turns out it was developer.
thx gents for all the inputs!
