View Full Version : Miscellaneous Emptying the Waste Toner Bottle
DaisySteiner
07-22-2015, 10:13 AM
Hi Guys
Does anyone know how to empty a Waste Toner Bottle on a Konica C224.
Splinkter
07-22-2015, 11:25 AM
I wouldn't recommend it as it's likely to just create a mess.
Your supposed to replace them.
DaisySteiner
07-22-2015, 11:32 AM
Its okay , Ive figured it out and its now working.
Yeah I know you are not meant to but it was a dire situation.
Thanks anyways :)
hotfuser
07-22-2015, 12:14 PM
Thanks anyways :)
if you empty it take the see through window off and clean it so you do not get the waste toner full when replaced.
DaisySteiner
07-22-2015, 12:31 PM
Thanks Guys
In the end I had to unscrew the clear plastic clip and empty it out. I wasn't expecting this to work , must of been a fluke , but it did :) . I have x2 new WTB arriving today so just needed a temp fix.
allan
07-22-2015, 01:25 PM
It's that almost all of the time. IT guys have tried and failed almost every time. Just clean the thing before you pop it back in.
DaisySteiner
07-22-2015, 01:36 PM
Beginners luck , or I am just plain fabulous ;)
Yeah , I made sure I cleaned it and let it settle.
Thanks all x
EarthKmTech
07-22-2015, 01:46 PM
When the customer doesn't have a spare I simply use the vacuum cleaner to empty it and the detection window.
no mess, ever.
I then empty the vacuum into a thick bag and toss it in their garbage and warn them its not happening again and to order a bottle.
rrrohan
07-24-2015, 08:33 AM
ive completely removed the window section and covered the hole with duct tape once while waiting a day for a replacement to arrive
its not as messy and if its only for 2 days at most you will be fine
copier addict
07-24-2015, 04:20 PM
We just empty them. From the C250 all the way up to the e series. It is easy and saves a lot of money.
