gzartman
07-28-2015, 08:55 AM
I bought a used bizhub C252 as a secondary printer. The printer has existing settings from the original owner and I think I've cleared out most of the settings or altered them to fit my network. I've set the IP address using DHCP. I installed the latest Universal Konica driver from the Konica Minolta site on my client machines and when I try to to a network search to find the printer, it doesn't find anything. However, I can manually connect to it using the manual setup option in the driver dialog.
I have another bizhub C252 and the network search function works fine to find the printer.
My question is this. Is there some setting somewhere in the printer that prevents the network search function from finding it using broadcast? If there is such a setting, then maybe the original owner shut it off.
Thanks,
Greg
Thanks,
Greg
