View Full Version : Error Code C360
Mahmood
07-29-2015, 05:17 PM
hi
C360 with error code C5601 firmware updated and PRCB changed but still the same error.
any idea.
allan
07-29-2015, 06:16 PM
Did you open and close the front door to reset?
Does the code pop up at startup or during a job?
Mahmood
07-29-2015, 06:52 PM
yes I did, after resetting the error code machine will come in ready state then code will appear again.
allan
07-29-2015, 07:00 PM
Disable the HDD and do a ram test from service mode. The code explanation is vague so it could be a couple of things. Even keep the lan cable unplugged. Disable things like the fax and AU's. U can use [trouble isolate] for some things.
try to eliminate anything possible.
You can even try a machine data clear or just a error data clear.
