View Full Version : minolta bizhub c350 error c-0990 & c-0996
cantonakis
05-28-2008, 12:30 PM
Resently I got 2 minolta bizhub c350 after a page missfit from the LCD I am getting the c-0990 on the one with the fiery and the c-0996 of the the other. Does anyone know what is this and how to solve it please ?
Mark B
05-28-2008, 01:37 PM
Sounds like drawer codes. Reload the paper.
Accentcp
05-28-2008, 10:25 PM
LCC paper shift I think.Straighten that stack and look behind drawer in cabinet!!!
ni311
06-01-2008, 12:00 PM
c-0990
LCT Elevator Motor malfunction (Elevator malfunction)
The Elevator Motor Pulse Sensor (PC10-LCT) cannot detect both edges of H/L
even after the set period of time has elapsed while the Elevator Motor (M5-LCT) is
turning backward/forward (raise/lower).
Action
1 Check the motor and sensor connectors for proper connection, and correct as necessary.
2 Check the connector of motor for proper drive coupling, and correct as necessary.
3 PC10-LCT I/O, sensor check
4 M5-LCT operation check
5 PWB-H LCT replacement
6 PWB-C1 LCT replacement
c-0996
LCT Shift Motor malfunction
The drawer cannot be determined to be out of position even after the set period of
time has elapsed after the Tray Lock Solenoid (SL1-LCT) is energized after the
lowering operation is finished.
Action
1 Check the SL1-LCT connector for proper connection, and correct as necessary.
2 SL1-LCT operation check
3 PWB-C1 LCT replacement
I hope this help.
