View Full Version : C6000 Image Issue
big jase
08-02-2015, 05:30 PM
Has anyone seen this issue , there is a background half way down the sheet, looks like a blade not cleaning but i have swapped drums and grids, i also swapped over the cyan & black developer units over to test the dev unit .The fault disappears !
swapped units back and then this happens just on the 1st copy out
Please see attached photos 30097300983009930100
Mick01
08-03-2015, 12:03 AM
Hi,
Looks like your drum-developer distance is too close.
Try placing one piece of the orange tape (the tape that is used to stick the packaging) at the front of the drum unit where the developing units contacts the drum unit. This will slightly move the dev unit away from the drum. This should resolve your issue.
hope this helps.
big jase
08-09-2015, 10:12 PM
Hi,
hope this helps.
Thanks Mick01
you were spot on put some electrical tape on drum units fault gone
Mick01
08-09-2015, 11:59 PM
You are most welcome.
