View Full Version : Miscellaneous Disable doc feeder on bh363?
Motormount
08-06-2015, 12:39 AM
Is there an admin or service setting to disable the doc feeder whilst I wait on the latch? I can't find one in the manuals or at the control panel. Or just disconnect the cables (wish it were a quick disconnect, like the older models).
Thanks,
RB
Flash
08-06-2015, 01:37 AM
You should be able to go into the service mode, select System 1, and then select Trouble isolation and unset the document feeder.
wseyller
08-06-2015, 02:56 AM
Just have the customer stick a ream of paper on the back corner of the doc feeder lid. It will work just fine while you wait on the part.
Sent from my XT1254 using Tapatalk
copyrooks
08-06-2015, 04:21 AM
You should be able to go to service mode and I believe system 2 look for adf settings and then just unset the feeder selected. Could be mistaken with the 224 models but worth a shot.
**turns out that's for 224 so yeah, double checked the manual and trouble isolation would be the way to go
Motormount
08-06-2015, 05:04 PM
Thanks Flash. Yep, another look at the manual and that's where it is. Yesterday I couldn't see it - HDTV (hump day tunnel vision) I guess - could only see Friday from there.:p
