View Full Version : Error Code C-2557 on a C554e
Guy Milner
08-06-2015, 09:40 AM
Hi ....
Ongoing problems with error code C-2557 on a C554e.
We have changed the K dev unit and K toner, but still got the code ( intermittantly )
Vacuumed out the hopper and visually checked all the workings within it.
We are taking a motor and sensor off of a C224e today to take up for testing.
Anyone experienced this on the C554e?
Thanks,
Guy
There is a mod bulletin for the c224e regarding this issue. I believe it will be the same for 554. You need to change the bushing.
D Colour
08-06-2015, 11:56 AM
We had this problem on a 224e. Forced toner, code went for a day, then replaced the dev, code went for a week. Turns out a plug was loose. If you remove the output tray, there is a sensor on the black dev, check it.
Mr Spock
08-06-2015, 10:45 PM
I had a new install of a c454e do this. After trying everything for 3 weeks I found a bulletin on the issue I was having. The paddle inside the sub hopper is not moving correctly against the sensor so the unit does not add toner to dev unit. There are cut-in serial numbers for the other models but not the c454e series. I ordered the sub hopper assembly and have not heard from them in 2 weeks.
I am not logged in but search for c255x in the bulletins if you have access to KM.
splblazer91
08-07-2015, 02:02 AM
Replace the hopper assy. Have never had a developer unit go bad on one of these. Its always the dang hopper.
malthus
08-07-2015, 06:49 PM
modified bushing available from minolta original one seized up in hopper and threw up code deepending on colour
Guy Milner
08-10-2015, 05:11 PM
We have replaced the motor and p.i sensor for K. So far, so good.
