Bizhub C360 Cannot Scan to SMB 2008R2 Server
  • copierwhisper
    • Mar 2013
    • 78
    I just installed seven C360, they took the place of C353's. The old machines scanned to folders on their 2008R2 Server, but the C360 is giving a login error. Any ideas? This is what the IT person said:
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub C360 Cannot Scan to SMB 2008R2 Server
    Login error would indicate that the MFP can connect with the server, but is being denied based upon permissions. How did you back up and push the old 353 one touches to the new machine? If you didn't use pagescope data admin, then it's possibly a bad password. I would start at the control panel and create a new one touch using the MFPs ability to browse out to the network...Once you see the sever you are trying to access, the MFP should pop up a user name and password field. Enter the correct info and if it works, you should see exactly what folders the server is truly sharing. Also, you may have to change the domain name info under the SMB settings in ADMIN/NETWORK/SMB. This should not have a .XXX extension. Emujo
