View Full Version : Envelopes C1070
ullrich
08-10-2015, 01:10 PM
Any suggestions for getting envelopes to print correctly? We are getting a double image use the envelope fuser.
allan
08-10-2015, 01:50 PM
The machine could be running too fast. Did you select the proper media type?
ullrich
08-10-2015, 02:40 PM
The envelope fuser only has 4 paper weight settings and I have tried all of them.
lucky13
08-12-2015, 11:41 PM
The envelope fuser only has 4 paper weight settings and I have tried all of them. I have had this issue before
for a workaround I had to lower the fuser temp 5-10 deg and rotate env 180 deg to print on end of env I believe there is a spring kit to put more pressure on fuser rollers. I see this when printing black on 20lb bond and envelops good luck
