View Full Version : Konica 7022 f-41-1
mrfuser
08-13-2015, 11:15 PM
I have a client with a few old 7022 and two of them now have f-41-1 codes and won't clear.
Any ideas?
mrfuser
08-14-2015, 01:34 AM
Okay, I am guessing that it is a fuse blown somewhere that controls power to the scanner. Anyone know where that fuse is?
Luther
08-14-2015, 03:29 AM
its more likely the scanner motor that took out the scanner control board, if you can find them replace them as a set, the motor probably took out the scanner board, they are both located under the lens cover under the scan glass
mrfuser
08-14-2015, 05:00 AM
Thanks, tried that already no good. I'm sure it is a power issue just can't figure out which line fuse feeds scanner.
CraigW
08-14-2015, 01:31 PM
I always Ohm out the ICP fuses soldered to the boards.
Then tack the leads of the replacement fuse across the open ICP, and insulate.
