View Full Version : Error Code FS-C8020
copymex
08-14-2015, 02:04 AM
error code 2101 and copier never connected to a network. how to reset, regards rob
tmaged
08-14-2015, 02:43 AM
If it's a C2101, then it's black developer related. completely separate from any kind of sending error.
copymex
08-14-2015, 03:53 AM
Thanks but code is 2101
Kyo fan
08-14-2015, 09:01 AM
Is it C2101 when you turn on the machine, or sending error 2101 when you try to scan something?
copymex
08-15-2015, 06:25 AM
Its code 2101, it comes during warm up and stays, copier has never been network connected, suspect I need a reset code?
blackcat4866
08-16-2015, 01:33 AM
Not every problem can be solved by a reset. Sometimes you have to fix something first. What does your manual say? =^..^=
copymex
08-16-2015, 02:11 PM
Manual says Network not connected, which is correct. Network never connected to this copier. also, manual says cannot connect to network, which is also correct, as no connection is available. Why copier is stuck on code 2101? Any clues would help, regards Rob
blackcat4866
08-16-2015, 03:15 PM
If it were me, I think I would turn off TCP/IP in System Menu > System > TCP/IP > set to Off > TCP/IP6 > set to Off. It's described on pg 9-19 of the operators guide. =^..^=
copymex
08-17-2015, 09:28 AM
Yes, would love to enter system menu and look, however, cannot enter system menu with code 2101 on copier. Can enter tech code (108- ----) but can find no escape from 2101. Therefore my original question How to clear/ escape 2101? Regards Rob
So how could the MFP work before ?
C2101 in service manual says : error with BK DV
2101 in user manual says : error with FTP or SMB (when using)
In the second case the printer cant be blocked.
I think tmaged was right, your problem's completely separated from any kind of sending error.
you don't look @ the right manual :D
tmaged
08-17-2015, 03:43 PM
Send errors will let you bypass or cancel them to use other functions. Post a pic of the display. It has to be the C2101, black DV error.
