View Full Version : Error Code Bizhub 600 Code C-2401
rizwan143
08-20-2015, 03:56 PM
Hello to All,
I have a Bizhub 600 with a code of C-2401. I changed the ECL lamp corona assembly with another machine but same code. Also bought new PRCB & checked that too. Same code. :(
Also Trouble Reset done by pressing Utility while powering on the Machine.
I am unable to access Service mode by going with Stop 00 Stop 01. IS there any other way to access service mode also ?
Any solution for the code C-2401
allan
08-20-2015, 05:26 PM
Check the end-block connector on the drum cradle and the frame side. The connector on the frame side tends to crack.
copier addict
08-20-2015, 09:24 PM
The is a bulletin concerning the code.
PROBABLE CAUSES:
1. C-2401 normally indicates a failed erase lamp, although it is caused, in this case, by a bind in the drum carriage.
Remove and inspect the drum carriage assembly. Run the Toner Cartridge Set mode as well as the Developing unit/Drum.
2. Open ICP6 on the PRCB.
Check for broken or shorted wires in Tray 3 area and repair as necessary. Replace the PRCB (p/n 57AA -902 1J). After replacing the PRCB, go to the Service Mode and set softswitch 32, bit 1 to "0" (OFF). Then re-flash the firmware and, after restarting the machine, set softswitch 32, bit 1 to "1" (ON).
Hope this helps
FixStuff
08-21-2015, 01:06 AM
Had this recently. Replacing the HV Unit fixed it in my case. I found the answer on another thread on this forum but can't find it now.
rizwan143
08-21-2015, 04:30 AM
What is the HV unit?
rizwan143
08-21-2015, 04:33 AM
PROBABLE CAUSES:
Hope this helps
If you dont mind please tell me the Flashing procedure & required files. I changed the Sw 32 to Off but dont know about flashing it.
allan
08-21-2015, 06:12 AM
Try leaving the front doors open when you start the machine and then accessing service mode.
rizwan143
08-21-2015, 06:32 AM
I am on the service mode. But how can i flash the firmware ?
allan
08-21-2015, 06:34 AM
Do you have the firmware? Do you have a manual?
FixStuff
08-21-2015, 06:36 AM
Power supply
rizwan143
08-21-2015, 06:40 AM
Sorry No :(
rizwan143
08-21-2015, 06:42 AM
Power supply
Can the Voltage supply cause this problem of C-2401 ?
The problem of C-2401 came in the morning with a warming problem. The machine said "Now warming up " & never being warmed even after 20 minutes. I opened the Drum assembly & inserted again & c-2401 started coming.
allan
08-21-2015, 06:54 AM
Did you change the consumables like the drum blade and developer? is the machine dumping toner.
Firmware is not going to fix this.
rizwan143
08-21-2015, 07:02 AM
No, Nothing changed like drum, cleaning blade or developer. I have a Di-5510 machine also in my shop. I tried with that machine Corona assembly ( E L Lamp) on bizhub 600 but it still says same error c-2401 :( .
I spent money already on buying a new PRCB board from another city but still same problem.
I think this might help you to get new solution that :
I sent "Old board" to dealer in another city & he confirmed that " I tried this board on new Bizhub600 & it given same code on new machine too so the board is having a fault so buy a new one" So, he sent me a working fresh board from there but still same problem on my machine with new board.
Any Idea ?
copier addict
08-21-2015, 01:51 PM
HV is the high voltage power supply, not the DC power supply. It supplies high voltage to the drum, dev, coronas.....etc. etc
FixStuff
08-21-2015, 02:39 PM
Sorry for the confusion. I changed the DC Power Supply. DCPS1. I'm not saying it's definitely the cause but it fixed my problem.
Here's the other thread I mentioned. Thanks to Mick01 for the answer.
http://www.copytechnet.com/forums/konica-minolta/75057-bizhub-750-error-code-2401-a.html (http://www.copytechnet.com/forums/konica-minolta/75057-bizhub-750-error-code-2401-a-2.html)
rizwan143
08-21-2015, 03:24 PM
Do the Bizhub600 & bizhub 750 error code C-2401 have same meaning ?
& should i check DCPS1 power supply now ?
Can i check the voltage with multimeter to verify its working or not ?
rizwan143
08-24-2015, 05:22 AM
Update : I tried 2 Working PRCB on my machine but both gets Same error & then even board are not working on there machines too :( . What can be the fault which is making board blow out in moment.
Please tell what things should i check in my machine so i wont loose other board too :(
copier addict
08-24-2015, 01:29 PM
Did you read the bulletin I posted earlier? It says to check paper trays 3 and 4 for shorted wires that then blow the PRCB. Fix these shorted wires before replacing PRCB or it will blow it again.
rizwan143
08-25-2015, 06:41 AM
Right now going to check Tray 3 & tray 4 wires in bottom. Do you have any manual please to check for shorted wires. Please help me. I cant waste more board :(
Please help me in finding shorted wires of tray 3 / tray 4
rizwan143
08-25-2015, 09:20 AM
Update : C-2401 Solved :) :) :)
It was the wrong polarity of Wires of ECL lamp& now its solved :).
But now the machine keep saying " Now warming up." but never warms up.
Please tell the possible solutions.
