Bizhub c250
  • Gab
    • Aug 2015
    • 666
    Bizhub c250
    Error c5357 appears. When machine warms if i open and close front door appears again and again. When warming finish and open and close front door error doesn,t apper no more and i can work. I checked all cooling funs and they are ok. Somebody tald me that i have not put machine right on paper cabinet.
    Also the image for black is light and not vivid( at the beginning first 1,2 letters of each line are ok but all the rest isn't. Also when i print consumables life image is ok) . I replaced black IU with some others from othermachines with no result. Can any body tell me how can i fix it?
  • Gab
    • Aug 2015
    • 666
    Re: Bizhub c250
    Also i noticed that lettersat first 2cm areok then they decome light. Also when iprint consumables life form machine print is ok, And when i print number of copies for about 5cm copy is ok but the rest is light
    • allan
      RTFM!!
      • 5459
      Re: Bizhub c250
      2nd Transfer pressure problem? Jam the machine if the paper is almost past the transfer section and check the image density on the belt.
      Whatever
      • rrrohan
        • Sep 2011
        • 1977
        Re: Bizhub c250
        I find cooling fan errors are usally correct, the fan is buggered
        I do them on mine sites fairly often in C360 range due to the dust
        • Gab
          • Aug 2015
          • 666
          Re: Bizhub c250
          I replaced the whole fusing unit with another and the problem remains.
          • rrrohan
            • Sep 2011
            • 1977
            Re: Bizhub c250
            He wasn't referring to the fuser, he was talking about the ITBU
            Sent from my SM-G900I using Tapatalk
            • Gab
              • Aug 2015
              • 666
              Re: Bizhub c250
              Sory, I am not familiar with Konica Minolta machines. I am a Ricoh tech.
              Can anybody tell mewat is ITBU .
              • allan
                RTFM!!
                • 5459
                Re: Bizhub c250
                Image Transfer Belt Unit.
                The big belt running across the drums.
                Whatever
                • Gab
                  • Aug 2015
                  • 666
                  Re: Bizhub c250
                  I have tried with 2 other belts from different machines with same result.
                  • allan
                    RTFM!!
                    • 5459
                    Re: Bizhub c250
                    I am not saying its the belt.
                    Whatever
                    • rrrohan
                      • Sep 2011
                      • 1977
                      Re: Bizhub c250
                      The belt is primary transfer, secondary is the transfer from belt to paper.
                      • Gab
                        • Aug 2015
                        • 666
                        Re: Bizhub c250
                        Anyway , please tell me what do i have to replace or clean or calibratre (and where it is).Thanks
                        • rrrohan
                          • Sep 2011
                          • 1977
                          Re: Bizhub c250
                          Get it to print a photo on A3, when it is feeding wait a few seconds and open side door mid print. See what the print quality is like on the paper prior to it going through fuser.
                          Check how it looks on the transfer belt, remove if nessary. If it looks OK on paper prior to the fuser make sure its not got the green levers set on envelope
                          If it looks crap on just the paper but not the belt check the transfer rollers
                          If it looks crap on the belt let us know
                          • Gab
                            • Aug 2015
                            • 666
                            Re: Bizhub c250
                            I have made as you said . Image on belt is too light , i can't see it directly . In order to see it i have to watch it from too close and at an agle. Also i tried with an othertransfer roller with no result.
                            i.e I took the machine from a customer (i sold an other) . I changed machine when belt need to be replaced. I reset belt and use the same. Also i asked customer and he told me that copy quality was ok till it stoped (for belt replacement)
                            • Gab
                              • Aug 2015
                              • 666
                              Re: Bizhub c250
                              Also i made some printings with same results (for 1,2 cm at the begining is ok and as we getb away from the beginning it get lighter
