View Full Version : Miscellaneous Bizhub C360 consumable life counter
jwagner
08-27-2015, 05:57 PM
We have replaced the imaging transfer belt, and drums, prior to them blowing the fuse, but the Counters do not reset. how do you go about resetting the counters, or are you better off just leaving them at 0?
copier addict
08-27-2015, 06:03 PM
The drum counters clear themselves, the transfer belt needs to be cleared manually. Go into service mode- counter- life- new release. Select transfer belt open the front door and press Start.
They will show 0 when they are cleared.
allan
08-27-2015, 06:27 PM
Does the drum counters clear.
jwagner
08-27-2015, 07:21 PM
haven't checked yet - some of the other counters are not indicating an end of life date. wondering if last person didn't install the PPLM life stop firmware. if I check the firmware version, what am I looking for to see if it has been installed?
thanks
allan
08-27-2015, 07:23 PM
What is Softswitch 51 on?
jwagner
08-27-2015, 07:51 PM
11110000
allan
08-27-2015, 07:56 PM
What is the hex value? F0? is should be 30.
copier addict
08-27-2015, 08:15 PM
11110000
This is the correct softswitch setting for PPLM. And switch 55 should be 00001100. And switch 50 should be 00000001
Hex for switch 51 should F0
Mr Spock
08-30-2015, 02:44 AM
thanks
Most machine will not show end of life until approx. 30% of life has been used.
allan
08-30-2015, 03:15 AM
Ok must be a regional thing.
