View Full Version : Power Line Monitoring
bigmark60
08-28-2015, 02:44 PM
Just curious what all of you guys are using for monitoring Power lines when you have a suspect power issue? I am looking for other options that will allow the technician to come back in say 24/48 hours and upload the report to the PC, or to there phones. We are currently using a solutions from Innovolt, but are looking for other solutions. If possible please include make/model info any help would be appreciated.
NeoMatrix
08-28-2015, 02:53 PM
Here in Oz we telephone the power company and they send a line-tech out with a power line monitoring meter. The techo plugs the monitor into the mains grid of the premises and then returns in a week/month or so to graph the results. The power-tech will confirm any transients/sperry on the supply and send the field-guys out to fix the issue. Sometimes it's an active or neutral wire in from the mains power pole or ground. Sometimes it's the mains transformer on the pole.
Unless you have big switching industrial motors in or around the premises you could get away with a UPS or PC style power filter.
HTH
jam-o-matic
08-28-2015, 03:02 PM
I threw the same question out to our small dealer group, with this model Fluke 1710. I got several responses that the Fluke was easy to use & had plenty of good info. I ordered one of these, a little on the $pendy side, but if we can save some tech hours & blown boards - it will pay for itself in 9-12 months!
Fluke VR1710 Voltage Quality Recorder (http://www.myflukestore.com/p5824/fluke_vr1710.php?gclid=CI7xl6n2y8cCFRCCaQod9NAJKw)
I can update once i have run at one of our construction trailers with a generator :mad:
bigmark60
08-28-2015, 03:09 PM
wow, that is pricey. $1100 there is a model we are looking into upgrading too by innovolt that is suppose to be able to be read on an android or iPhone that is much cheaper. Innovolt P1003/1000 and has an interface that plugs right into the phone. total of about $250-300 for the two devices needed. But I know there are some other models out there so just trolling for other options before we buy 10 of these new ones.
blackcat4866
08-29-2015, 02:30 AM
I've had one of these for 5 or 6 years, and it works quite nicely. The only hard part seems to explaining to the enduser that I'm not their guy when it comes to diagnosing the cause of power issues, or cleaning up the power. I'm just there to discover/monitor. =^..^=
Tonerbomb
08-29-2015, 02:38 AM
I've used both INNOVOLT and ESP Next gen PCS units. They both work well. The next gen is what I currently use, It's easy to use and get the info from and you can print out or save the file for the customer, maybe a little pricey, not really sure on cost.....................
