View Full Version : Konica 7155 (HP9055) Drawer 1 and 2 not lifting.
catgoldfish
05-31-2008, 03:32 AM
Hi there:
I'm not familiar with these machines at all. Just wondering if anyone could help me out. Drawers 1 and 2 of the Konica 7155 are not lifting at all. The paper deck and drawer 3 are ok. Thanks.
nmfaxman
05-31-2008, 04:20 AM
They could be locked out in service mode because of lift failure.
I don't remember the codes but this kicked my ass once.
Check 25 mode.
siraphop
05-31-2008, 04:40 AM
check 47 mode main23 multi 1,2 pull out tray does motor lift up
if not you need to check motor / connector / pcb.
Downunder
05-31-2008, 04:42 AM
nmfaxman is probably correct with this one. Had a refurbed 7165 go out after extensive testing. After delivery same fault. Must of been a spike. Turned out to be switched off.
catgoldfish
05-31-2008, 05:07 AM
Thanks guys for the input. I'll check this on Monday.
Luther
05-31-2008, 01:36 PM
If they are grayed out go to 25 mode ,sw settings, dip switch 18-1 thru 9 should all be zeros if the trays gray out again then there is a lift problem, good luck
