konica minolta 2010f image density question
  • brent
    • Nov 2008
    • 1208
    making copies off the glass is fine.. making copies from the doc feeder the copies are really dark
    I went into users choice and made the adjustment for density adf there are 2 options there
    then I went into tech rep and turned down the density just for grins.. but was curious If
    there was a setting or something someone knew about.. again this is just for the doc feed
    platen is fine. thanks
    brent
  • allan
    RTFM!!
    • 5459
    Re: konica minolta 2010f image density question
    That setting is to force gradation failure in a way it lifts the density of the lower end up. Normally the DF copies are to light.
    Try to replace the developer, it could be overtoned.
    Those machines are getting really old!
    Whatever
    • brent
      • Nov 2008
      • 1208
      drum and developer are at 19 percent.. I see what you are saying.. and yes I know these machines are old as dirt. and of course they use the doc feeder on every copy. because its easy. lol
      brent thanks
      • allan
        RTFM!!
        • 5459
        There is a grid voltage adjustment in tech rep mode.
        Whatever
        • brent
          • Nov 2008
          • 1208
          I seen that adjustment.
          I didn't know if that would fix what I am dealing with or not. I will toy with it next call out there
          • allan
            RTFM!!
            • 5459
            Probably not. Just an idea.
            Whatever
