View Full Version : Error Code e000025-0001 for IR5050
latif.abd
09-06-2015, 02:02 AM
Please help me i've got an error e00025-0001 for my IR5050,I tried browsing the web about this error and majority of them are saying that this is a toner motor issue. but i've replaced the toner motor, it doesn't change, remain the same, it doesn't work. pleas help me. what should I do to fix this error problem?
vigour
09-06-2015, 03:05 AM
The motor will blow the DC controller sometimes.
Read these posts
http://www.copytechnet.com/forums/canon/93525-canon-ir5075-toner-supply-problem.html
http://www.copytechnet.com/forums/canon/91396-ir5070-e025-001-a.html?highlight=e025 (http://www.copytechnet.com/forums/canon/93525-canon-ir5075-toner-supply-problem.html)
GasMask
09-08-2015, 01:58 PM
hi
have you replaced the sub hopper drive essembly?
dan7777
09-08-2015, 02:08 PM
Read these posts
This will probably fix the machine. You can buy a fuse for the dc controller. They look like resisters. Or take a fuse off another board. You just go to the controller and ohm out the fuse. The motor shorts and blows the fuse on the board. About 50% of mine made it. A lot cheaper than a board but still a takes a while. The pdf shows the fuse number. E025-0001 by replacing fk2-0813-000 motor and fu15 when necessary on the dc controller.
