drwevil
09-10-2015, 06:21 AM
Hi
We have a CLX-9352 that at home position the scan lamp doesn't come on when you use the ADF.
The scan lamp does come on if you copy or scan off the glass.
There doesn't seem to be a way to turn the lamp on in service mode.
If you push the ADF down switch by the left hinge the lamp flashes brightly moves to home position under the slit glass when you release it flashes dimly and moves to copy off glass position .
The good machine in the show room flashes brightly when you release that switch then moves to copy off glass.
Any Ideas?
Any Ideas?
