Bizhub C550 Missing Network Tab (#5) under Admin Settings
  • mj12
    • Sep 2015
    • 9
    Looking for any assistance in getting back the network tab on the C550. I found one article on here regarding my situation (http://www.copytechnet.com/forums/ko...setting-2.html) which referenced this image found here (http://www.copytechnet.com/forums/at...etwork-tab-jpg) however, when attempting to use the arp -s command, I always get returned bad argument. I have printed the Configuration Page and confirmed that I have the correct mac and the IP is matches what is displayed in the Configuration Page. Is there any other way to correct this?
    Regards,
    Jason
  • mj12
    • Sep 2015
    • 9
    Re: Bizhub C550 Missing Network Tab (#5) under Admin Settings
    After doing so more research it looks like my last resort is to obtain the NVRAM Reset Tool and perform the NIC Reset? Question is where do I find this firmware/software? Do I need to buy it? Any help would be appreciated.
    Regards
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      Did you try to reset the network settings in the service mode?
      • mj12
        • Sep 2015
        • 9
        Where would I do this at? I have performed an initialization, but never saw a screen regarding the network settings.
        • CompyTech
          Super Tech
          • Feb 2011
          • 706
          You're right it's not there, I just checked on a C550. The newer ones have the individual settings you can initialize.
          • mj12
            • Sep 2015
            • 9
            Any other suggestions?
            • CompyTech
              Super Tech
              • Feb 2011
              • 706
              I found this on the onestop support page:
              Program Release Information
              Model:bizhub C650/C550/C451/C353/C253/C203
              MFP Firmware Ver. GCQ-J8, GDQ-J8, GEQ-J8
              Subject: [bizhub C650/C550/C451/C353/C253/C203] NVRAM clear firmware (Jig Firmware )
              2008/07/18
              Konica Minolta Confidential 1/2
              These are jig firmwares that clear NVRAM for bizhub C650/C550/C451/C353 / C253 / C203.
              You may be able to repair a defective NVRAM by using this firmware.
              1. Release version and download file name
              The newly released program version and download file name are as follows.
              [Release version]
              < C650/C550/C451/C353/C253/C203 jig firmware>
              Model Program Name Ver. Program File Name Checksum Note
              bizhub C650 Jig firmware GCQ-J8 A00H0Y0-F000-GCQ-J8(00).EXE 0E9A
              bizhub C550 Jig firmware GCQ-J8 A00J0Y0-F000-GCQ-J8(00).EXE 8E57
              bizhub C451 Jig firmware GCQ-J8 A00K0Y0-F000-GCQ-J8(00).EXE 7D69
              bizhub C353 Jig firmware GCQ-J8 A02E0Y0-F000-GCQ-J8(00).EXE 91B0
              bizhub C253 Jig firmware GDQ-J8 A02E0Y0-F000-GDQ-J8(00).EXE 9139
              bizhub C203 Jig firmware GEQ-J8 A02E0Y0-F000-GEQ-J8(00).EXE AFA0
              [Download file name]
              A02E0Y0-F000-GC6-J8(00).EXE
              A02E0Y0-F000-GD6-J8(00).EXE
              A02E0Y0-F000-GE6-J8(00).EXE
              PRI_ DLBT0802274EN00.doc
              1) NVRAM Initialize.
              This operation clears all data except the information on counter list on the first page.
              2) Reset NIC settings.
              Only the settings related to the network are cleared.
              The setting related to the network is the following items.
              -Administrator Settings >> Network Setting
              -Administrator Settings >> Fax Settings >> Network Fax Settings >> Internet Fax Advanced Settings
              -Administrator Settings >> System Connection >> OpenAPI Settings
              -Administrator Settings >> Printer Settings >> Network Timeout settings
              -Administrator Settings >> Administrator/Machine Settings >> Input Machine Address >> E-mail settings
              -Service Mode >> CS Remote Care >> Server Set >> Send settings
              3. Procedure
              1) Install the CF card with the correct firmware installed into the into the MFP with the defective NVRAM, and turn on the MFP.
              2) The following screen is displayed.
              NVRAM Initialize.
              [YES] [NO]
              NIC setting erase.
              [YES] [NO]
              3) Select [YES] for the function that needs to to be initialized and press [START] after [YES] has been selected.
              NOTE [START] is not displayed if both [YES], or [NO]. is selected. Only one choice can be made at any time.
              4) If Completed is displayed, NVRAM or NIC rest is completed.
              5) Turn on the MFP.
              Perform the following when you do a NVRAM Initialize:
              (Note)
              After clearing NVRAM and turning on MFP for the first time, NVRAM is initialized according to the model/FW version of the
              MFP where the NVRAM is installed. While initializing, hour glass screen is displayed for about 90 seconds. Do not turn off
              the MFP while the hour glass screen is being displayed.
              6) Make following setting in service mode.
              System1>Marketing Area
              System2>HDD>
              System2>Option Board Status
              System2>Image Controller Setting
              System2>Software Switch Setting (required for bizhub product only)
              Switch No. :10
              Hex Assignment: :02
              7) Turn off/on the MFP again.
              8) Follow the setup procedure outlined in the installation manual for the model which this procedure was performed.
              • mj12
                • Sep 2015
                • 9
                Well I think I am down to trying to find this magical firmware.
                • mj12
                  • Sep 2015
                  • 9
                  Had a copier tech come out, after about 2 hours he determined he need the firmware after trying everything that I had already done. He wasn't sure if he still had the firmware since they don't service MK anymore but he thought he knew someone that might have it. Anyone know of a copier tech in San Diego area that can service this machine or even better provide me firmware?
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    you need more than the magical firmware - you need a suitable compact flash card 128-256mb will do it and obviously a reader/writer and the software.
                    Someone should have the kit to do it - i still have it in my car yet have used it only once in the last 2 years. dying generation of machine now...
                    • mj12
                      • Sep 2015
                      • 9
                      I have either progressed or regressed... I was able to obtain a 128mb card, did a hex edit of 00's on it and loaded it using FIT with Mosel2_cf.tar.gz. After doing the reset I received the page asking for entering serial numbers. Is this normal? From what documentation I had found it did not mention this. Where do I find the serial numbers? Just look at each item for the serial number or is there something more to it? In a prior thread on here it was mentioned to someone else with a different model to look at the service manual. I have the bizhub C550 service manual 2008.06 Ver. 8.0 and I was unable to find any information regarding this. Any help in directing me would be appreciated.
                      • CompyTech
                        Super Tech
                        • Feb 2011
                        • 706
                        The serial number it wants is the MFP serial number. It's on the back of the machine, you can enter it in Service mode: System 1, Serial Number input, select printer and enter it there. The rest are up to you if you want to enter them. You may have to do the Installation procedure as well if you get the "lines of shame"(color lines) on color copies.
