View Full Version : Konica 7055 error f36-2
tonyadf
06-03-2008, 10:25 AM
Ive got error f36-2 on a Konica 7055 copier.
The thermisters, thermal fuses and lamps are ok so I thought it would be a reset job.
Ive tried dip sw 3-1 but I may not be entering the command properly.
Haven't got much info on Konica as I usually look after Ricoh kit.
I would appreciate help from anyone who is more familiar with these copiers.
Thanks guys. Tony.
laserman06
06-04-2008, 02:25 AM
I personally do not work on that model, but I do work on other Konica models. I searched Konica's site and found a couple of things. One is the correct procedure to reset the fuser codes and the other is dealing with intermittent 36-02 codes. Hope this helps.
laserman06
06-04-2008, 02:27 AM
OOPs, forgot to attach the files. So here they are.:D
tonyadf
06-04-2008, 03:46 PM
Many thanks for the manual page, everything reset perfectly.
Tony.:)
glauberstedile
06-24-2008, 03:31 PM
Ive got error f36-2 on a Konica 7022 copier.
The thermisters, thermal fuses and lamps are ok so I don't kwon as do it.
At the others manufacturers have as reset this problem.
Thanks guys. Glauber.
tonyadf
06-25-2008, 09:27 AM
Konica 7055 reset. may be the same as yours
Tony
redhotrob
06-26-2008, 10:45 AM
With your 7022, or any machine in this series, all you need to do is touch those darn temperature sensors on the heat roller for them to act up. When I did service those models, I always carried a set of the sensors in my trunk stock. It got to the point that I wouldn't want to change the heat roller or clean the sensors without having a spare in my car.
glauberstedile
06-30-2008, 02:29 PM
Thanks, That's ok.
chejay127
07-16-2013, 05:01 AM
Thanks, That's ok.
Sir I am also having this kind of error code, i did try to reset those codes to zero then turn off the machine, when i power on the copier the error is gone and it will warm up for a few minutes but when I hit print it wont make a copy but display the same error code which is f36-2.. please help..
