Hi There,
for those who have had the same issue and might take a look at konica Minolta website for latest driver,just found the universal driver with no option and additional configuration in device properties.
also there is a problem with SMB scanning. The MFP and PC are connected through a TP-link switch and ping test from both sides were successful and print operation and also Twain scan by photoshop has no problem.the shared folder on the root drive has the full access for everybody as user or guest.
when try to send scanned document to pc ,for a moment you can see the file in the folder ,but couldn't be open,and after a while it vanished with this error " deleted due to error " is displayed on MFP monitor and in error detail described as "Server Error ."
SMB function is enabled in windows features and also Microsoft Net framework 3.5 and 4.X is installed. but the problem exist after all these adjustments.
I just wondering file sharing encryption could make such a failure or not.
So if you know about the special driver for win 8.1 and also solution for SMB scanning ,please share with us.
