View Full Version : strange problem bizhub c451
mik77
09-29-2015, 08:40 PM
On each working half are good and half ago the defect. Strange thing is that the mold vertically and horizontally.
The defect does is printing pdf, jpg, than from any program.
immaging units are new and internal tests are perfect.
the machine prints 140,000
Cosa ne pensate.
Thank you in advance
allan
09-29-2015, 09:06 PM
How does copies come out?
You need to rephrase that, your question is difficult to understand.
Do you know how to print half-tones in service mode?
mik77
09-29-2015, 10:08 PM
excuse my English.
halftones-mode service are perfect
of a work of 10 prints, 5 or 6 the problem occurs.
As you can see from the test, the defect is in the upper part of the sheet.
Prints only black and magenta, yellow is not printed
allan
09-29-2015, 10:39 PM
you say copies are ok or not?
Did you reinstall/reseat the yellow imaging unit?
blackcat4866
09-29-2015, 11:35 PM
Print this. It will tell us more:
allan
09-29-2015, 11:37 PM
Print this. It will tell is more:
That will work well.
mik77
09-30-2015, 08:31 AM
copy is used little
imaging unit yellow new
test pattern ok
It could be the laser or the ram???
allan
09-30-2015, 10:29 AM
Print blackcat's test print and post that. Without knowing if it's limited to printing or if it's happening with copies as well we can really eliminate problems.
emujo
09-30-2015, 01:36 PM
Pull laser unit and clean dev/toner droppings..I think that will clean up the voids, I would replace 2nd x-fer roller as a option for the poor color transfer. A lot of internal test prints are black only, problem would not show up unless you are running color. Emujo
mik77
09-30-2015, 09:06 PM
copy the problem does not occur.
It is like the machine had problems to process the data.
I'll try to replace laser, ram and controller MFP.
thanks for your advice
Synaux
10-01-2015, 03:31 PM
If I am understanding all this correctly, I had the same exact issue with a yellow IU last week. It would come and go. Replacing the IU with a spare one cleared it up. Ordered a new yellow IU that day.
Go ahead and replace all that expensive stuff if you want to...replace the yellow IU first (worst case scenario: you will have an extra yellow IU for the future).
Are there any P codes?
mik77
10-01-2015, 08:58 PM
printed vertically the problem occurs at the top.
printed horizontally the problem occurs in the head.
consequently can not be the yellow IU.
