View Full Version : C280
CrapAimer
10-06-2015, 09:08 AM
Hi All
Was trying to copy over the address book from a C280 to a C220 came up with product name different is there a way around this ??
George
EarthKmTech
10-06-2015, 10:27 AM
data administrator will absolutely do it, not sure how you are trying to do it.
Data Administrator - PageScope Utilities - Solution Software | KONICA MINOLTA (http://www.biz.konicaminolta.com/solutions/ps_utilities/dataadministrator.html)
mo0651
10-06-2015, 02:50 PM
Have had success with opening the abbreviated text file with note pad...then editing the model number in upper left corner. This has worked on C203 to c253 and BH223's.
CrapAimer
10-06-2015, 05:11 PM
Thanks for the info done as you said opened it up changed the file name and hey presto it worked a treat
Many thanks
George
wseyller
10-07-2015, 12:26 AM
That doesn't work on newer models. I use data administrator which works between most bizhubs.
Sent from my XT1254 using Tapatalk
JR2ALTA
10-07-2015, 12:40 AM
Always double check SMB scans after transferring with Data Administrator. The encrypted password is often HIT OR MISS. Sometimes just transferring again will fix it.
wseyller
10-07-2015, 01:35 AM
I've always assumed with data administrator that password don't carry over. It had never for me anyway.
